Tor unstable
Unstable tor connection
The app came a long way but Tor still is very unstable most of the time, any revisions on that part? Used to tor being slower but on envoy it drops connection every single time without fail.
I find it one of the killer features for envoy, but its still broken.
Hey @Panicseller are you on the 2.3.0 beta or on 2.2.14? thanks!
Im on 2.3.0 since today, hoped the update would resolve the issue, but still same
I mean there is an arti version update pending for 2.3.1 (the tor library we use), but we haven’t seen the instability you mention. Can you further describe the symptoms? are you getting the banner? or are the accounts not syncing or something like that? anything of relevance in the logs? Do you get the same experience on mobile vs on wifi? Any info helps - thanks!
Getting the bar notification and the red shield almost every single time
AnyhowException (Electrum sync failed: general SOCKS server failure and errors sending request to the onion url
what server are you connected to?
Default foundation servers
Another quirk since the update, cant make a send tx because the keyboard does not go down after filling out the address. Larger screen iphone btw
ok please try changing to personal node, and paste this mocmguuik7rws4bclpcoz2ldfzesjolatrzggaxfl37hjpreap777yqd.onion:50001 or this l7wsl4yghqvdgp4ullod67ydb54ttxs3nnvctblbofl7umw6j72e5did.onion:50001, those are the foundation servers’ onion addresses (you can verify this claim here: envoy/lib/business/settings.dart at v2.3.0 · Foundation-Devices/envoy · GitHub).
Please try this and report back, it might just be an issue with the “Foundation severs (default)” option not driving traffic properly?
Thanks! Will try this and revert back. Any difference between the two links or basically same?
exactly the same, Envoy defaults to one or another randomly, or if one fails too much it changes. Nothing different on our end though
