Did you guys stop sponsoring the channel? Thought QNA was going to make educational content but then but I noticed they’re now promoting cold card.
Unfortunately that relationship came to an end in a way that was not expected. That also means the educational stuff is also shelved.
I’m sure you can join the dots ![]()
Understood!
Btw, I think they might be using a photo of you on their YT thumbnails (not sure if that’s you or not).
Can you link to an example?
