Question: 2FA Codes Sorting/Grouping
Hello, I had a question reguarding the 2fa codes app. I’m wondering if there is a way to “group” 2fa codes in “folders” so to speak or really just a UI box of somesort and then when selecting it your taken into a deeper level that could show you either another “folder” or more 2fa codes.
I’m asking because personally I have a million 2fa codes at this point where I now have to use the search feature even though my phone has a big screen. It would be helpful to group them into sections of like “email” and “work” and “financial” and “developer” like for github, and other tools, etc.
If its not currently present what are your thoughts on adding this as a feature??
Not yet but this is a good idea!
cc @Jack
Added to the backlog (SFT-6802), thank you for the feedback!
Sweet, thanks guys!
