Support Request Template - If you are seeking support, try to answer the following questions when creating your topic. It will vastly improve the speed at which someone can help. If you do not require support, delete this text and create your own topic intro.
Problems with the firmware
Installed version 2.3.2 installing 2.3.9 at 98% stops, what to do
There was a known issue in 2.3.2, you can see the reply below in order to perform the upgrade. Thank you!
