Personal Node Indicator Envoy
I think It would be cool if there was a little indicator that always shows at the top of envoy that indicates you are connected to you own electrum server.
I think this would be a cool peace of mind feature, maybe similar to how sparrow always shows you whether you’re connected and utilises different colours to indicate whether you are connected to a public or personal server and even the type.
Im sure you could even copy the colour scheme sparrow uses for this indicator to create unity/ continuity between the two.
This would be a powerful feature. What do you think?
Also looking forward to being able to load in multisig output descriptors into envoy too down the road!
Most node runners are connecting via Tor, and we already have the shield that turns red when it cannot connect. That does leave out those only connecting via clearnet or locally though, so perhaps we can expand the shield functionality in the future to accommodate this.
Nice idea.
