Password for unlock
Are there plans to support passwords instead of a PIN for unlocking the device? Letters, symbols, numbers.
Or are these deemed redundant because of implemented brute force protection
Prime will support PIN/Password choice at launch.
@qna Very nice, will this roll out to core as well?
Core has had this for years.
@qna Are you serious? Where can I find it? I can only input numbers, not words or symbols
Press the character key (aA1 - bottom right) on the PIN screen.
@qna cant believe I missed that, thank you!
