It would be really useful to have seed XOR. Are there any plans to incorporate this feature?
We do not have any plans to add Seed XOR at present.
Could be a good app for a third party to build for Passport Prime in the future though.
I was looking where to find this. Would be a great feature to add.
Thanks for using the search function and registering your support!
why isnt there a % indicator in passport core, its such a basic feature, btw when can we expect the next firmware upgrade for core, its due for very long now
You can see the % in Settings → Device → Battery.
We experimented with displaying the battery percentage in the top bar where the battery icon is being displayed, but the number always looked bad, too crowded in very little space.
RE: Next Core update - 2.3.6 should be out in the coming weeks, but it’s a very minor one, only changing the initial set up flow for new devices in order to align it with the upcoming Envoy 2.0.0, zero changes for already set up Passports. After that we’ll be releasing 2.4.0 that is a major rewrite of all the PSBT handling, it will allow for Passport to handle much bigger PSBT transactions by optimizing its memory usage. We are still early for this however, we need to run many tests and we don’t have a release date for it yet, we will make the proper announcements via official channels when we are ready to ship or the beta is available.
Thank you!
