Passport Envoy Displaying Insufficient Funds
My Envoy is displaying insufficient funds when I’m trying to send from my wallet. My balance is displayed and clearly shows I don’t have insufficient funds. Anyone have this issue or a resolution?
Hi there!
This can happen for multiple reasons, most probably because the selected coins are not enough to pay for the fee+send amount. I presume you are on mainnet, right? Do you have other unlocked UTXOs in the wallet?
Thanks!
@CryptoHough are you still getting this issue?
Yes
OK thanks. We are working on a fix right now. Appreciate the patience.
@CryptoHough can you update to Envoy 2.1.0 and let me know if the issue is fixed?
I’m on Passport firmware 2.3.9 and Envoy is 2.1.1(2).
Just rec’d the insufficient funds message.
Ended up restarting Envoy and was able to send.
Not sure if this is still an issue for others, but I certainly just experienced it for the first time.
Anything useful in your logs @Bacco_E ?
I can share the logs with you QnA. What’s the best way to do that securely?
I’ve DM’d you.
