No way to completely reset Passport and PIN code?
There seems to be no way to completely reset Passport? Reset only resets the content, but not the PIN code. Then again typing PIN wrong 20 times destroys the device, so that is not a solution either. And one cant change the PIN code on resetted device without creating or restoring a wallet before? And even then there is no way to completely remove the PIN code?
This is crazy.
What if I forget the PIN code on the device that I have resetted and putted aside for a couple of years? Goodbye the whole device! What if Im affraid that someone might be able to recover the PIN code from the device and I want it to be gone? No way to do that sorry!
Really? No way around this?
Hey, @anonfinn
Unlike typical electronics, a security device cannot afford a simple ‘Factory Reset’ option. The reason for this is removing the chain supply attack vector, where devices looks perefectly new, altough they aren’t. Like Ledegers.
PIN shouldn’t be forggoten, and even if so, that’s where the mnemonic phrase backup can be used for recovering your Bitcoin wallet keys.
hey @anonfinn
You are correct, our current gen passport cannot be factory reset in a way that the PIN creation process is also reset. A strategy that would resolve some of the mentioned concerns would be to change the pin to 000000 first, then factory reset the device. However, you are correct in your assessment regarding a device whose PIN you have forgotten - that device would be locked forever. You would still be able to recover your funds using the mnemonic, or even better, your funds with all the accounts metadata if you recover from an encrypted backup in another Passport.
In any case, just like you did, a lot of people voiced their concern regarding this implementation so we decided to review it for Passport Prime. Our new device will be able to be completely wiped and factory reset, including the PIN.
I always had doubts about resetting a wallet that it’s 100% unrecoverable. Let’s say I wipe a passport to re-use it, is some data not recoverable through forensic tools same way they do for mobile phones?
When I decide to change wallets (including a fresh seed) I always destroyed the previous hardware wallet and ordered a new one. Does that make sense or am I just burning money?
Nothing to worry about. When you erase, we overwrite the data with blank 0’s. So even if someone were able to break in, all they would extract is a blank ‘secret’.
Thanks for confirming this, saving me some future money
I have a follow-up question please.
How can you verify that seed is wiped off in the SE via factory reset?
From what i understand:
1/ PAD and pairing key remains in the bootloader after reset.
2/ Encrypted+XORd seed is wiped in SE with a blank 0.
But SE is closed source, so how do you confirm that the seed is wiped off? Has anyone been able to verify this? Thanks!
Hey just responded to your email, but will post here too.
To be clear, there is no ‘factory reset’ in Passport. You can only erase the seed, but not the PIN.
It is defined in the code here. Essentially we save a bunch of zeros in a special case to overwrite the secret.
Thank you for your response and correcting me. I did mean to write erasing the seed there. :slight_smile: So I do understand the part where we are sending these instructions to the SE to overwrite the secret.
But I was more concerned about the part on how the SE is handling these instructions internally. And if it retains a copy of the seed somewhere at all before rewriting it with zeros. I guess I’m just getting paranoid that the seed is stored inside the closed source SE. So it cannot be verified what goes inside there.
I think I found the answer to mitigate SE trust issue in any possible way. I can use the Temporary seed option instead, so that the seed never gets stored in the SE, and is removed on device turn off. Love the different options from passport!
Whilst the SE is closed source, even if it were to somehow copy the seed data unknowingly to another slot for reading later, it would still require further compromise of the MCU (built by a separate manufacturer), which stores the OTP required to read the XOR’d seed info.
Moreover, this is a generic secure element, not specific to Bitcoin and has various security certifications (e.g., https://www.microchip.com/en-us/products/security/trust-platform/trustflex/trustflex-aws-iot-authentication/aws-iot-greengrass-atecc608b). It does not just go around copying slot data. It only performs operations when requested.
