Hello team,
When enabling magic backups for Prime, and you have multiple devices on the Envoy app, is there any cross data of other devices (passports) and its wallets included in the backup? Preferably not.
Hello team,
Each Passport Prime MB is distinct and tied to the corresponding Master Key hash.
thanks ![]()
Hey @Panicseller, here’s a detailed breakdown of what each backup file is and how they work Passport prime issues - #104 by Jack
As @qna mentioned, each Passport Prime Magic Backup (or manually downloaded backup file) will only contain information related to its internal apps. The Envoy Magic Backup (or manually downloaded backup file) will however have a view of everything in the app (without any seed material, of course), including all the Passport Core and Passport Primes paired, their names, account names, transaction tags and notes. It is intended to be a way to recover your Envoy form a fresh install to your last backed up state, so all this metadata is saved there. It is also true however that Envoy only sees Bitcoin wallet app’s information, and has no access or visibility to any of Passport Prime’s 2FA/Keys/Vault or any other app really, so only metadata of paired bitcoin accounts is saved in the Envoy Magic Backup (or the manually downlaoded backup).
Thanks for the info and the read. The way you formulated your post makes it sound like there are seperate magic backup options for the hardware and envoy individually. But as far as I know there is not, does that mean my envoy data is included in the magic backup for prime?
So they are indeed two separate things:
To your point however, Passport Prime Magic Backups used to default to whichever selection mode you had for Envoy Magic Backups in KeyOS 1.2.0. So if you were a manual Envoy user (Envoy Magic Backups off) the default for Passport Prime Magic Backups was also turned off, and viceversa. This link was broken in KeyOS 1.2.1. After that version, Passport Prime defaults to Magics Backups = on for everyone regardless of their Envoy Magic Backups status, but you will now see an “Advanced” button on the top right corner of the onboarding screen where it explains Magic Backups. If you tap that, you will move forward with the manual mode, regardless of your Envoy Magic Backups status.
Furthermore, the toggle you see in the Magic Backups line in Passport Prime under Settings → Backups is read only now, but we have short term future plans to make it actually toggable, so users can change between magic and manual at any time, not just during onboarding.
We probably haven’t done a great job at explaining this, likely due to the intricate, detailed and nuanced nature of it all, but I hope this can shed some light to it. Thank you!
Thanks for the explanation, I get the gist of it now. A more nuanced question; Regarding anything wallet related like transaction tags, metadata or anything else for that matter that gets included in the magic backups made through prime: is it possible to see the addresses or overall holdings?
Some data I would like to keep 100% seperated regardless of encryption and shamir sharing. I would have to start fresh and make new magic backups using new nfc cards, or how would you suggest I go about it?
So if you enable Passport Prime Magic Backups, none of the tags and labels will be saved anywhere - all that is handled by Envoy at the moment, Passport Prime is totally unaware of what you decided to name what transaction or what addres. All this is handled Envoyside, and included in the Envoy Magic Backups.
In Envoy we use BIP329 for tags and labels, which essentially means creating a JSON file with the address or txid that has the tag or note. This is absolutely required, we need to know which transaction or address to assign the tags and notes to when recovering, so the addresses and txids with labels are absolutely backed up as part of the Envoy Magic Backup. However, we also back up the wallet descriptor in order to be able to fetch the balance, and this includes the xpub, so this would include anything with and without a label.
After digging deeper I found that the Passport Prime Magic Backups also back up the descriptor as part of BDK, so xpubs would be there too.
If you want to keep anything address related out of our servers, even if it is inaccessible by us or anyone really, you should turn off Envoy Magic Backups and create a new Passport Prime seed with Passport Prime Magic Backups turned off. When erasing Magic Backups form Envoy, an erase call will be triggered and the magic backup will be completely removed from our system in 24hrs (we give users a day in case they regret deleting their wallet and want to emergency recover), after that it’s gone forever. But if you don’t trust us and you already had Envoy Magic Backups enabled, you probably want to start anew in Envoy and Passport Prime, with Envoy Magic Backups turned off.
So the short answer is: if you absolutely don’t want any public key related info in our servers even if fully encrytped (and on our way to moving it to post-quantum) and unassociated to you, then you probably want to start anew and go the manual way on both Envoy and Passport Prime.
Thanks!
thank you for the detailed explanation
I think I should have added a bit more context on my setup.
So its more so about keeping everything wallet related from the passports away from the magic backup I opted for on the prime. I dont mind prime data going through envoy servers, I chose to do it that way, not so much for the passports
No then you are good! If you have Envoy Magic Backups disabled, that’s the one where the infrom from other passports is stored. Passport Prime Magic Backups does not store anything related to any other Passport may have paired to the same Envoy instance at any given time. Passport Prime only cares about itself, ans is totally unaware of whether you paired another 10 device or it’s the only one paired for Envoy, so no, it does NOT store info about other devices in its Magic Backups!
Will this be accompanied by the separation of 2/3 + keychain vs 3/3 keycards? It seems like from a use case this has to be separated to enable this (otherwise people might enable this later having started with 3/3 keycards and no shard on the device keychain). I also think there’s an opportunity to clarify the difference here: Magic Backups (to the server) and Shamir shard (to the keychain). I’d lean towards renaming the later from Magic Backups to seed shard backups (or something similar). You’d then have Passport Prime Magic Backups, Passport Prime Seed Shard Backups, Envoy Magic Backups, and Envoy Seed Backups.
Also one more omission during onboarding.
If you are restoring seed phrase, magic backups are turned on by default. You can’t choose to use all 3 cards for backup neither during onboarding nor in settings after masterkey is in.
Perfect, this clarifies it for me
Yes, the plan is that when you toggle the switch, if you go from manual to magic you are asked to tap two keycards that will get overwritten with the new shard setup, and tap the third one to wipe it. And if you go from magic to manual, you will be asked to tap all three of them.
ANd yes, naming convention can get messy, especially when you are coming up with new concepts that are not trivial to grasp but you don’t want to get too technical either… Definitely something to look into on our end - thanks for the feedback!
This is indeed an unintentional side effect and is already tracked internally (SFT-6945). The original line of thought was that since you imported from a backup, you already had a backup in place so you didn’t need to perform one, meaning there was no need to place the user in the backup flow. Skipping this however defaults you to being a magic user, and until we enable the toggle to move form manual to magic and vice versa in KeyOS 1.4.0 you are stuck being a magic user if you recover from seed. It is a high priority fix, but we had to leave it out for 1.3.0 as we are already wrapping it up. Thank you for bringing it up, and apologies for the inconvenience.
Thank you for information.
I’m glad that the fix is already in process.
