Liana and Time locks
I recently watched a video (BTC Sessions) on the Liana wallet which incorporates the concept of time lock and the ability to create custom multisig set ups which can be used in setting up estate plans. Was wondering if this is something that will be available with Foundation currently or in the future.
Hi,
Yes we plan to add Miniscript support later this year to both Prime and Core.
do you mind ‘replying’ to people as though they are neither programmers nor code writers??? the question was- is Passport going to implement ‘time lock’ and ‘ability to create custom multisig set ups’. What do we get as an answer? ‘we plan to add Miniscript support later’… What the heck is Miniscript??? how ‘time lock’ and ‘multisig set ups’ are related to Miniscript??? how a normal person is supposed to understand an answer like this?
I assumed it was a round about way of saying yes. I am not a programmer and know enough to be dangerous. I did find this which may at least provide a little more insight to Miniscript.
The OP made references to a 1 hour long video on the subject, so I felt safe to assume they knew that Liana is a miniscript wallet.
