I have updated my Envoy and Passport to the most current versions available. Most recently 2 days ago updated my Passport. Now my personal node, RoninDojo, is not connecting. I re-paired my electrum server in the app but it states it 'couldn’t reach node". Has anyone had an issue with connecting their electrum server to their wallet? Any fixes? Suggestions
Hey, here’s a few things to check and feedback on:
- Have you checked the logs of your electrum server? Is it fully synced?
- Are you connecting over Tor? If so, are you seeing any Tor related errors in Envoy?
- What format are you using when entering the personal node info in the Envoy privacy screen? It should look something like
tcp://youronionaddress.onion:50001
