How do I sign a transcation with microsd using envoy app? core as signing device
  • What are you trying to achieve?
    Trying to sign a transaction with a microsd because It won’t let me with QR code
  • What steps are you taking to try and achieve this?
    Not sure how to do it, I believe I gotta put a psbt file onto the microsd but not sure how to get it from the envoy app
  • What are you seeing or experiencing to suggest that something is wrong?
  • What version of Envoy are you using?
    2.1.1(2)
  • Does your query relate to the mobile wallet or a Passport account?
    mobile wallet
Hi,
This is not currently supported in Envoy. For now you’ll need to use a wallet that supports microSD signing like BlueWallet or Sparrow on your computer.
We plan to add this to Envoy in Q1 of next year.
So how do I do it now? What steps would I need to take?
It’s all in the videos I linked for you. Let me know if you get stuck when following those step by step instructions.
I just uploaded the wallet to sparrow. But it’s showing a different balance on sparrow from envoy. I see less sats on sparrow. I haven’t done any transactions yet.
I fixed it, I searched up how to fix it. I had to change gap limit from 20 to 40, then the transactions showed up properly. It could be problematic because If you want to import a wallet to somewhere else, the balance could be off a bit and you won’t even know it unless you knew the exact balance before hand. Not that it’s foundations fault, just a technical thing.
