Feature Request : Importing Temporary Wallet from Encrypted microSD Backup
Dear Foundation Team,
I appreciate the great work you are doing with the Passport hardware wallet. I have a feature request that I believe would enhance the user experience.
Currently, when using the Import Temporary Wallet function, it would be useful if Passport could allow users to import their seed phrase directly from the encrypted microSD backup. This would streamline the process, reduce the risk of errors, and improve privacy as well as security.
Is this something that could be considered in a future firmware update?
Thank you for your time, and I look forward to your thoughts.
Best regards,
Hey this could be a cool idea and something we should be able to add after a little more consideration.
I’m going to make a ticket for us to discuss and track internally.
Thanks so much for the suggestion!
Thank you.
Looking forward to seeing it
