Feature Request: Allow connect to private home node
Im curious what you guys think about adding in the abvility to sync with your own home bitcoin node. I currently run my own node and thats honestly a big hinderence to using envoy when it comes to syncing transactions and wallet ballences, etc.
Would be a nice to have. Are the re any plans to add this in the future?
Unless I miss understood your question, that option is already there for a while now.
Just tap the pull down option and change from Foundation (Default) to your personal node address.
OOff, did not see that, thanks for pointing that out
