Feature request: Abel to create a 24 Seed Word, Able to Wipe KeyCards, Scramble Numbers on Keyboard
Good Day,
  • Would be nice to have the option to create a 24 Seed Word at Setup
  • Check if Cards have NFC Cards have anything on them and give option to wipe Card
  • Be able to scramble Numbers on Keyboard when entering pin
Hi and thank you for your feedback! I can’t promise any or all of these will make it to future firmware, but we’ll certainly discuss the pros and cons internally.
  1. @Jack lets make a backlog item for this as part of the advanced flow
  2. You can already verify Keycards and create new backups overwriting the existing data (with warnings). Do you have another use case not covered here?
  3. @Jack lets make a backlog item for discussion
Hi Qna,
Thank you for your replies, regarding the Cards it would be nice to have an option just to wipe the Cards when verify Backup
Understood, thanks. cc @Jack for backlog
