Evnoy hot wallet "Received - Awaiting confirmation" question
I’ve noticed with Envoy (hot wallet) it generally takes a long time to update the status from awaiting confirmation to confirmed status on received transactions. Sometimes it takes 30 mins or longer, other times 10-15 mins. The block on mempool.space that had the transaction was already mined. Is there a rule that it only changes status in Envoy after at least 3 blocks have been mined/confirmed on the mempool, or is there no rule and it should change right after the first block has been confirmed? What would cause this delay? I am connected to my own node using fulcrum indexer. Just curious because the time it takes to show the confirmed status in Envoy is so random and all over the place with each transaction I receive. :face_with_spiral_eyes: Hope to get some clarity on this. Thanks guys/gals.
This is being adjusted in 2.3.0. Its currently set to 3 confs and will be set to 1.
