Support Request Template - If you are seeking support, try to answer the following questions when creating your topic. It will vastly improve the speed at which someone can help. If you do not require support, delete this text and create your own topic intro.
What are you trying to achieve?
I want to use envoy for two very different use cases:
1: Connected with my cold storage (passport core) to use it maybe once a year max. Also easy firmware updates etc.
2: Use the app as hot wallet with maybe 1 monthly salary.
But I would love two have two PIN codes when I open the app which then opens Envoy either with the HHW account or the hot wallets.
So nobody in the public can see that I have a HWW when I use Envoy in the public. Yes, its a bit paranoid but we are talking about my live savings and that’s why I don’t use Envoy as a hot wallet much. -
What steps are you taking to try and achieve this?
I used the search in this forum but couldn’t find an answer.
So I reckon it’s not possible but maybe something for the future? -
What version of Envoy are you using?
the latest on iOS -
Does your query relate to the mobile wallet or a Passport account?
both
J
