Envoy watch only issue
  • What are you trying to achieve?
    trying to import my output descriptor into envoy to use it as a watch only wallet
  • What steps are you taking to try and achieve this?
    Im exporting the descriptor directly from my passport batch 2
  • What are you seeing or experiencing to suggest that something is wrong?
    Envoy seems to scan it but the circle stops right at the end and nothing happens it freezes. I have tried closing and opening the app as well as restarting my phone (envoy is on the latest version)
  • What version of Envoy are you using?
    Latest version as of today
  • Does your query relate to the mobile wallet or a Passport account?
    passport
Hey, this is not a supported feature in Envoy just yet. We do plan to add this at some point next year though.
I will make a separate note to handle the error a little more gracefully though!
