Envoy v2.1.0 is now live!
The latest version of Envoy 2.1.0– is now published on all your favorite mobile platforms! To download it, simply visit our download page or check for updates on your platform of choice.
WHAT’S CHANGED
In Envoy v2.1.0 we squashed a lot of bugs so we encourage all our users to update to have a more smooth and solid Envoy experience. Since Magic Backups have also been improved, we encourage everyone to perform a Magic Backup after the upgrade!
:magic_wand: Improved Magic Backups
:locked_with_key: Improved Tor reliability
:lady_beetle: Minor bug fixes
You can dive into the full release notes here
Are the servers down? Updated but no connectivity, either that or Tor
Team are checking this now @Panicseller
@Panicseller working for you now?
Not sure if this has been addressed but I updated my envoy through fdroid and once updated I launched envoy and it automatically edited and changed my saved personal node url to a fulcrum url. I don’t remember previous update automatically editing the address url.
Just so I’m clear, did you have a personal node set before the update? If yes, it changed to a different personal node URL?
EDIT - We’ve replicated the problem and are working on a hotfix. Thanks for the report.
I can confirm this. After the update, a Fulcrum address and version were displayed. I manually added my own electrs node and was able to reconnect.
Yes to confirm that is correct, I have a personal node that I’ve always had Envoy connected to and this new update had the url automatically change to some unknown fulcrum url.
Thanks. We have a hotfix submitted to the app stores and are awaiting approval.
Envoy v2.1.1 is now available for download.
This release is a fix for v2.1.0 with the details below.
• Fixed an issue where upgrading from a previous Envoy version could overwrite personal node settings.
Thanks everyone on the team for a fast hotfix. :+1: I can confirm the hotfix worked.
Sorry lost track, working for me yes :+1:
My phone automatically updated to V2.1.0 and now the app is not displaying my account values nor is it allowing me to send or recieve funds.
Ive checked on another phone with V1.8.6 and i can do everything.
Has anyone else experienced this? Will there be a fix quickly?
Okay thanks, ive done that but its the weekend so i probably wont hear anything untill tomorrow.
Just responded to your email @Trevor_Bello
I’m having the same issue. Just updated the firmware to 2.1.0 and can’t send txs. Also the envoy app isnt updating
Assuming you are not using your own personal node, check your node settings are set to Foundation (Default) in the Privacy screen @harryhood12
