Envoy bug
Hi guys, there seems to be a bug in the envoy update where transactions show a 0 sat / 0 usd tx fee.
Hey @Panicseller thanks for the report!
Just to confirm, are you on Envoy 2.0.1? Feel free to move to DMs if you prefer so, but do you thnk you could share a screenshot with me issue? Feel free to censor any sensitive info beforehand (like amount, txid, stuff like that). Also ok not to share a screenshot if you don’t feel comfortable!
I’d like to learn more about this issue though, as were not able to replicate it internally - are you able to replicate this behavior and find a pattern? Something like - does it always happens with passport transactions? Or maybe it only happens with Taproot transactions? Finding patterns like that should help us find the culprit sooner.
Thank you!
Hi @Jack
Its the newest update, yes. I can see the tx fees on the older transactions just fine, the single incoming transaction I had after the latest envoy update is the only one producing this issue. If you cant replicate it we can move this to DM.
Got it, thank you! We’ll get it fixed in one of the upcoming bugfix releases, thank you for the report!
No problem!
