Decimal point bug when sending from Passport Account
Is this the right place to report bugs? If not, please move and let me know where.
Using: Passport 2 v 2.3.5
Envoy v 1.8.6
iPhone 13 Pro Max iOS 18.3
This is for creating a send transaction in Envoy, from both the Envoy mobile wallet and also from a Passport Account.
When entering the amount to send, if entering the decimal point as the first character, the decimal point does not register and needs to be pressed a second time to properly register.
(If pressing another numeral first, including 0, first, the decimal point registers correctly upon it’s first push. Otherwise, when trying to immediately press the decimal point first, it needs to be pressed a second time to register.)
Obviously, everyone should always double and triple check their transaction details before sending, but if in a hurry, this could cause a 10x difference in amount spent!
Thanks for the great work being done at Foundation.
Replicating your bug, thanks so much for the report. I’ll add a ticket for a fix now.
