Hi, I can’t see balance or transactions on envoy. I use passport. The app had just updated when I opened it and that’s what you see in the pic when I open it.
Hi,
Are those grey bubbles pulsating or solid?
Pulsating = Trying to load and we might have a sync error
Solid = You have likely just hidden the balances and can undo this by swiping left on the account card
If they are pulsating, can you let us know the settings in your Privacy screen please?
- Improved privacy or better performance?
- Node setting
Could you please send through a copy of your Envoy log file?
Time : 2025-09-23T02:38:12.035919
Category : Migration
Message : Current migration version: 2.31, Required: 2.31, Requires migration: false
App version: 2.0.2 (27)
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-23T02:38:11.391420
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T23:24:40.686153
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T23:24:40.078340
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T14:59:40.815367
Category : Fees
Message : Cannot get Fees Exception: Couldn’t get mempool.space fees
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T14:59:39.912004
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T14:59:39.333372
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T14:59:29.712252
Category : Fees
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T14:59:28.325973
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T14:59:27.679572
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T13:39:17.931939
Category : Feed Manager
Message : TimeoutException: Timed out https://api.vimeo.com/users/210701027/videos?per_page=100&page=1, torPort: -1
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T13:38:40.424884
Category : Fees
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T13:38:39.424254
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T13:38:38.788192
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:35:11.517331
Category : Fees
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:34:14.609041
Category : NTP
Message : Error getting NTP time: SocketException: Bad file descriptor (OS Error: Bad file descriptor, errno = 9), address = 0.0.0.0, port = 0
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:34:14.607253
Category : NTP
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:33:02.228599
Category : Fees
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:25:37.043473
Category : Fees
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:21:52.635629
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:20:11.530036
Category : Fees
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:20:10.624990
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:20:10.057754
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:16:10.002200
Category : Fees
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:16:09.102021
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:16:08.545856
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:15:53.183304
Category : Fees
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:15:52.525630
Category : Migration:SanityCheck
Message :
Checking SuperWallet : “Primary (#0)”
Account directory: /var/mobile/Containers/Data/Application/4276DFDA-A5EC-4CC2-B253-6B1787DED7D5/Documents/wallets_v2/0440-A62C-CA13-C7F1_mainnet_1c985f63_acc_0
Found 2 files in directory
Validating account Type (witnessPublicKeyHash)
Account “Primary (#0)” (witnessPublicKeyHash):
Overall status for Primary (#0): ![]()
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:15:52.524607
Message : SanityCheck: Primary (#0) | mainnet | 1c985f63 →
ScanStore Size : 0
Scan Status: AddressType.p2Wpkh = false
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:15:52.466416
Message : Unifying accounts with id (Primary (#0)) 1c985f63 mainnet
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:15:52.052240
Message : Migrating account (AddressType.p2Wpkh) AddressType.p2Wpkh Primary (#0) mainnet
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:15:51.946778
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:15:51.946750
Message : Total accounts found: 1
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:15:51.818161
Message : Current migration version: 0.0, Required: 2.31, Requires migration: true
Library : None
Exception : None
Stack Trace : None
Time : 2025-09-22T12:15:51.664716
Library : None
Exception : None
Stack Trace : None
Time : 2024-10-12T23:53:34.154157
Category : wallet
Message : Couldn’t sync: Exception: Couldn’t sync to: Network.Mainnet (ssl://mainnet-0.foundation.xyz:50002)
Library : None
Exception : None
Stack Trace : None
Time : 2024-09-18T02:05:46.000059
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-09-03T12:19:16.456805
Category : connectivity
Library : None
Exception : None
Stack Trace : None
Time : 2024-09-03T11:30:04.769655
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-09-03T11:29:00.381900
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-08-08T12:05:16.967681
Library : None
Exception : None
Stack Trace : None
Time : 2024-06-11T21:29:44.137662
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-06-11T21:09:34.078415
Library : None
Exception : None
Stack Trace : None
Time : 2024-06-11T21:09:33.892287
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-06-09T08:26:44.280400
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-05-18T17:46:16.066548
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-05-16T18:16:54.144188
Library : None
Exception : None
Stack Trace : None
Time : 2024-05-11T19:29:06.523673
Library : None
Exception : None
Stack Trace : None
Time : 2024-05-09T14:26:50.509759
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-04-25T04:09:15.760942
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-04-15T20:10:57.955072
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-04-15T19:31:11.913930
Library : None
Exception : None
Stack Trace : None
Time : 2024-04-15T19:30:58.593535
Category : wallet
Library : None
Exception : None
Stack Trace : None
Time : 2024-04-15T19:30:54.502558
Library : None
Exception : None
Stack Trace : None
Time : 2024-04-15T19:30:53.516358
Library : None
Exception : None
Stack Trace : None
Time : 2024-04-15T19:27:12.633458
Category : wallet
Library : None
Exception : None
Stack Trace : None
Thank you. Do you only have Passport accounts connected, or do you also have a mobile wallet active?
I believe only 1 passport account. If there was a mobile account, there would a blue box under account details right. I never had an account with a blue box.
Correct. In that case, could you try deleting and reinstalling the app from the app store? After reinstalling, you’ll need to reconnect the Passport account.
Still the same thing after deleting and reinstalling
Can you try changing the node in the privacy screen to Blockstream? Restart the app after doing so and let me know if it changes anything.
Still the same
Okay I see it now. I just kept checking it and eventually it just started showing lol
Are you on Blockstream or Foundation node now?
Foundation
Ok thanks for confirming everything appears OK now.
