I’m running GrapheneOS stable on a Pixel 10 Pro XL. I am able to pair the device via Bluetooth and everything works for a while but when I come back after a few days it’s no longer paired and not listed in my Bluetooth devices. If I re-pair it from the system Bluetooth menu it connects and quantum link is reestablished without scanning any QR codes.
Hey @Mason.99999 - did you try just turning the device on without going through the pairing flow on graphene? I just tested on Graphene on a pixel 7 and while it’s true that the moment you shut down Passport Prime the device disappears from the paired bluetooth devices, the moment you turn it on it shows up again. I guess it’s just how Graphene/Android handle bluetooth devices - it only shows them while actively connected, even though they are remembered in the backgound. Please test this and let us know! Thanks!
Hi @Jack it seems to be working now. Perhaps was a bug with 1.2 and fixed in 1.2.1? It also remains in the Bluetooth device list now (like all others). Thanks!
