Will there be any update where we can import 2FA codes by entering a set up key ? I could not import a QR code from OKX , tried from my phone screen and my PC screen and it could not read it
Hey @themarchinghammer welcome to the copmmunity forum!
Yes, the ability to import a 2FA code by manually entering its secret is planned for KeyOS 1.4.0 (SFT-6861), although we have planned a KeyOS1.3.1 and a KeyOS1.3.2 before then.
However, KeyOS 1.3.0 will include the option to import 2FA codes from Google Authenticator via QR code, so another thing you could do until then is import the 2FA code to google authenticator, then upgrade to KeyOS 1.3.0 and import from Google authenticator.
Thank you
Will we be or able to enter 2FA codes from Authy or 2FAS Auth? I stopped using Google authenticator a long long time ago. Unfortunately, I do not have the key codes anymore. Only the backups in my iPhone iCloud
Regrettably Authy is one of those services that lock you in and don’t allow you to export your code: Confused new user - #5 by Jack
I have never heard of 2FAS Auth though, can you provide a link to the app so I can investigate it and see if we could add compatibility?
Thanks for the response. Here is a link to the second app
Best
Good news is 2FAS does allow to export the codes to a file, and we happen to be working on a file import feature for KeyOS 1.3.1, so I’ll try and sneak this particular format they use in there
Awesome Jack. Thanks so much!!
