1 prime - multiple users (trusted)
Would it be possible to have a single prime device for multiple users? Say for husband / wife type usage instead of having to carry around 2 of the devices…maybe storage limitation but thinking for a few secure website access, BTC storage, or even just 2FA…or maybe it’s just better to have 2 since they aren’t that much… I’m sure there is a use case but maybe not. I just ordered so looking forward to all the updates and progress!
If it’s in a trusted relationship, then there’s no reason two people cannot share a device. Storage should not be an issue unless you plan on keeping more than 50GB of files on there!
Problem is if you share it though, what happens when you are not together and the second person needs to access a 2FA code or security key?
