Currently when battery is too low, you get the bootloader for a second and the screen just turns off.
A notice to charge first would be helpful here, as it just looks as if the device is glitching out.
Thanks for flagging this. Prime already has a low-battery startup warning, but we’re tracking an issue where it can shut down before that warning is clearly displayed.
Could you share your KeyOS and bootloader versions from Settings → About once it’s charged? That will help us confirm whether you’re seeing the same issue.
I also have this issue. I’m on version 1.4
Thanks @Mason.99999. Could you also share your bootloader version from Settings > About once your Passport Prime has charged? That helps us confirm it’s the same issue.
My bootloader is 0.2.1. Does this not updated with the firmware (if not is there a way we should update it)?
The bootloader is separate from KeyOS and doesn’t update with normal firmware updates, so its version staying the same doesn’t mean your update failed. There’s no bootloader update you need to install for this.
We’re tracking an improvement to make the low-battery warning clearly visible before Prime shuts down. In the meantime, let it charge for a while before trying to power it on again.
Okay, thanks. Is that the most recent bootloader? Will there be an update process for bootloaders when new versions come out?
Newer bootloader versions exist, but bootloaders aren’t typically updated during normal operation. Having version 0.2.1 isn’t anything to worry about, and there’s nothing you need to do here.
We’re tracking the low-battery warning improvement separately in KeyOS.
GrapheneOS specifically bundles firmware and software into a single package to avoid version drift and reduce attack surface. I think Foundation should emulate this.
Regardless of the above, there was obviously a reason to update the bootloader and I like to maintain maximal update status. Is there a manual update option?
@Mason.99999 I understand (and somewhat share) the concern to be up to date on everything. However, there hasn’t been any security related updates in the bootloader. You should know we have the ability to trigger a bootloader update in every one of our updates, and we have very deliberately chosen not to do so yet because the improvements have been marginal so far vs the benfit they carry.
This type of upgrade is risky, and NOT advised unless strictly necessary. I want to be very clear in this regard: anything goes wrong, and I mean anything, from a misclick to a random cosmic ray bug, you risk permanently bricking your device, with no way to recover. This is not something that should be done lightly.
But if you really, really want to go against our advice, and want to update the bootloader regardless, here is how to do it:
I am on KeyOS 1.4.0 and bootloader 0.2.1
