Would it be possible to add a functionality so we can write backups to seedkeeper cards too? I would prefer to have a full seed backup on the encrypted seedkeeper cards instead of sd cards where I have to backup again a complex access code the backup.
Can you provide more info? I’m not familiar with seedkeeper.
Sure. These are Chip/NFC cards where you can store passwords/seedphrases on. They are encypted on a secure element chip inside the card. If you try accessing the data with the wrong pin a few times the data gets wiped automatically. This would be a great way to store redundant copies of a seed imo. The cards / the system is FOSS it also works together with Seedsinger devices. As the cards support NFC I assume it should be possible to enable the Prime device to write/read from them too.
Example of a SeedSigner that supports the cards.
OK thanks, I’ll log the request.
