Question regarding recent Coldcard issue
Using Passport Core with single sig + Passphrase. In light of the coldcard issue is this still secure? I like keeping it simple vs changing to multi sig.
As long as Passport Core generated the seed you should be ok. Now if you generated a seed on a coldcard and then imported that seed into passport then you are not safe.
Generated/created on passport core, not coldcard. Thanks! Feeling safe!
Nothing to worry about Tony, we’ve been doing extensive testing as well as around 40 external researchers since the coldcard exploit surfaced.
