Opening passport core
Hello team,
in light of certain events, could you advise how do go about opening a passport core to check for implants without ruining the device?
Hi @Panicseller,
We strongly advise against dismantling Passport Core to inspect it. Opening it risks damaging the enclosure or internal components, and a visual inspection alone cannot reliably rule out a sophisticated implant. We can’t offer a procedure that guarantees opening it without damage.
Passport’s supply-chain validation checks its provisioned cryptographic identity. That is a useful authenticity check, but it should not be interpreted as proof that every component is unmodified or that no physical implant exists. The mechanism is explained in our security model, and our Core hardware designs are publicly available for technical review.
If your concern is broader distrust of any single manufacturer, a multi-vendor multisig setup is worth considering. It reduces reliance on one device or vendor, but introduces additional backup and recovery responsibilities. That is a significant decision to make based on your own threat model, preferences and ability to manage the setup safely.
Thank you and I understand the risks, but willing to take them
Understood, and it’s your device. The issue isn’t whether you accept the risk, but that we don’t have a verified disassembly procedure to share that guarantees avoiding damage.
The published enclosure designs are the relevant technical reference, though they aren’t a step-by-step teardown guide. If you decide to proceed, I’d recommend working with an experienced hardware technician and verifying your recovery backup beforehand because we cannot guaruntee the device survives a teardown by a customer.
Okay thanks, yes it looks like I will have to accept that I will probably break the device. But i’m okay with that, the drawings will help me figure out what belongs there
Drill out the 2 screws under the battery label. Then use a spudger to pry open from the top and sides, you should be able to get it back together again but ideally youd want to find replacement screws.
Thanks, appreciate it!
