I am using the most current 2.3.5 vs of Envoy on Android. Is there anyway or consideration to add, if not, to lock Envoy and require a pin or password to open the app? I have other apps that require a login or PIN to open beyond that required to unlock the phone.
In Envoy on the very bottom you have menus that you can click on. Click on “Privacy” and scroll to the very bottom and enable “Application Lock” this will allow you to either use biometrics or pin to open Envoy. Hope this helps.
Fantastic - Thank you!
