Hey @Bacco_E. just checking in - what did you mean tap new item a second time? It should work with a single tap… can you double check this works for you too?
It is a single tap…my bad. All good.
I was referring to starting from the 3 dots in the upper right hand corner. It’s a double tap from there.
May I make a suggestion, the red font on grey background isn’t easy on my old eyes. I’m probably not the only one that feels that way.
Thanks Guys.
Is there a “how to” for the new features?
I want to learn how to apply my imported Core seed into Prime.
Thanks.
No docs updates yet, but those will be ready before, or shortly after, the main release is available.
Temporary application of Vault seeds is not active in this version, that will be v1.4
EDIT - @Bacco_E just remembered that a ‘New Item’ button is also at the bottom of the main Vault screen. No need to go via the three dot menu. You might need to just scroll down (that’s why I forgot about it)
Thanks QnA…I noticed the New Item button in the main vault screen as well.
Thanks for the update on the Vault app seed application.
