Incorrect active key
Was wondering if anyone has tried to send from the default wallet on prime to a passphrase wallet created on prime. All using envoy. I’m getting an “incorrect active key alert” “ the key involved in this transaction does not belong to this wallet”
although I do have the correct passphrase wallet pulled up. Using maple ai the clanker offered some work arounds but curious if this is a known issue or am i slipping up somewhere? I’d do the workaround but got nervous because coincidentally I tried this lastnight and then that scam email showed up!
any info is appreciated. Thanks
Hi @dugga,
It sounds like the passphrase wallet is selected on Prime when it needs the default wallet’s key to sign the outgoing transaction. The receiving wallet doesn’t need to be selected during signing.
I’ve checked the code: switching between the Default and Passphrase tabs in Prime’s Bitcoin app also switches which key is used for signing. You don’t need to clear your passphrase.
Please try this:
  1. With your passphrase applied, select the receiving passphrase account in Envoy and verify its receiving address on Prime using Verify Address.
  2. Switch to the Default tab in Prime’s Bitcoin app, leaving the passphrase applied.
  3. In Envoy, create a small test transaction from your default account to the verified passphrase-wallet address.
  4. Check the destination, amount and fee carefully on Prime before signing.
  5. Afterwards, switch back to the Passphrase tab to check the receiving wallet.
The distinction is that Prime must have the sending wallet selected, not the destination wallet.
The active-key warning is a key mismatch, not a tampering alert, and doesn’t itself establish any connection to the scam email. Please don’t follow that email’s links or enter your seed words or passphrase into any website or AI tool.
If it still happens with the Default tab selected, let us know your KeyOS and Envoy versions and exactly when the warning appears.
Perfect, that worked thank you!
