I dispise Envoy
I have zero respect for Envoy. It’s a constant nuisance. My stupid device almost never connects to it. Now Envoy shows me there’s a 1.4.0 firmware, and I’d like to update, but Prime just won’t connect. Bluetooth is enabled, and the device even shows as “Connected” on my Android phone’s Bluetooth list, but the device says “No Connection to Envoy.”
How am I supposed to upgrade? Gah, I really just want a transaction signer, I never asked for a “companion app”.
I’ve tried to remove the device from Envoy and pair it again. I’ve tried to disable and re-enable Bluetoth on the device as well as on my phone.
Damnit, I don’t even want Bitcoin apps on my phone, just to give wrench attackers less to go on.
On the device I go to Settings → Update, and there’s a nice blue button saying “Check for New Version”. I press it, nothing happens. I press it and I press it, and now my finger is LITERALLY bleeding.
I just want to update the firmware. I hope that’s the firmware that will let me update future firmware without Envoy, because I have absolutely zero respect for that app. The day I can uninstall it, I will have a MAJOR party.
When I disable Bluetooth on the device, Envoy goes from showing “QuantumLink” as “Active” to “Inactive”. So there’s some connection between the two. And yet when I go to Settings, it shows “No Connection to Envoy”.
What even is this thing? I have a Master’s degree and a brain the size of the universe, and yet I’m struggling with this stupid app. Do you even expect newbies to use this product?
Sounds like a stale BT connection.
To reset the connection completely:
  1. On Prime, open Settings, tap the Envoy connection entry and select Disconnect from Envoy, if available.
  2. Remove Prime from Envoy’s device list.
  3. In your Android phone’s Settings → Connected devices → Bluetooth, find Passport Prime, tap its gear icon and select Forget or Unpair. Check Previously connected devices too.
  4. Close Envoy completely, then restart your phone and Prime.
  5. Unlock Prime and use Pair to Envoy in its settings. Scan the initial QR with your phone’s camera, then complete the animated QR scan in Envoy. Don’t pair directly through Android’s Bluetooth menu.
Alternatively, you can update straight to KeyOS 1.4.0 without Envoy using the recovery file:
  1. Make sure your recovery backups are available and charge Prime to at least 50%.
  2. Download KeyOS-v1.4.0-Recovery.bin. Use this file, not the CoreSystemRecovery file.
  3. Copy it onto a USB drive or microSD card. You’ll need a USB-C adapter or card reader if necessary.
  4. Power off Prime, then turn it on with a single press of the power button.
  5. While the Foundation logo appears, repeatedly tap the power button to open the boot menu.
  6. Select Recovery → Firmware Recovery. Do not select Factory Reset.
  7. Connect your drive to Prime’s bottom USB-C port, select the recovery file and follow the prompts. Leave the drive connected until installation finishes and Prime restarts.
Once updated, you can use Sparrow with QR codes for signing without Envoy. Version 1.4.0 also supports manual future updates, so Envoy isn’t required for that workflow. Before uninstalling it, ensure your backups don’t depend on the recovery share held on your phone.
If you’d still like us to investigate the connection problem, send your phone model, Android and Envoy versions, privacy mode, and fresh Envoy logs as a file attachment to hello@foundation.xyz.
Thanks! Your recipe for resetting the connection resembles what I’ve been doing. Nonetheless I followed it closely, and it resulted in the same situation: “No Connection to Envoy”.
I was, however, able to upgrade to 1.4.0 using the recovery method, which I wish I had known about earlier. Just for completeness, I tried to pair to Envoy again after upgrading, and ended up with the same issue. I do see the “Manual Update” function for firmware now, which fills me with relief. In my case I don’t need Envoy for anything else, so I’ve uninstalled it.
Thanks!
If you ever change your mind and want to connect with Envoy, I’d be happy to troubleshoot further. Just contact support hello@foundation.xyz
