First Transactions after loading onto wallet 5 years ago failed ned help
Support Request Template - If you are seeking support, try to answer the following questions when creating your topic. It will vastly improve the speed at which someone can help. If you do not require support, delete this text and create your own topic intro.
  • What steps are you taking to try and achieve this?
  • What are you seeing or experiencing to suggest that something is wrong?
  • What firmware version is your Passport running?
  • Which wallet software are you using in conjunction with Passport?
i am trying to do my first test transaction from passport to a wallet
i tried to scan the QR code with envoy but it was taking too long.
so i made the transaction on envoy then moved the sd card to passport and signed on the SD card, the SD card shows the file on the passport but, when i view the sd card the file on the phone does not appear and envoy can not very the psbt file.
is there a tutorial i can watch.
FW 2.3.11 is the version i use
Hi Mark,
Envoy supports transaction signing with Passport through QR codes only. It cannot import the signed transaction file from your microSD card.
First, try these adjustments to get the QR scanning working:
  • Use even lighting and avoid direct sunlight or reflections on the screen.
  • Adjust the brightness of the screen displaying the QR code, and slowly vary the distance between the devices.
  • When Passport is scanning Envoy, use the three small square controls beneath Envoy’s transaction QR to change the QR density. Restart Passport’s scan after changing it.
  • When Envoy is scanning Passport, use Passport’s up/down buttons to adjust brightness and left/right buttons to adjust QR density.
  • Keep the devices steady while the animated QR sequence is being scanned. If the progress keeps increasing, let it continue.
Our QR troubleshooting guide is here:
Since you’ve already signed the transaction and saved it to the microSD card, you can also broadcast that existing file using Sparrow. You do not need to pair Passport with Sparrow, import your account, or sign the transaction again.
  1. Download Sparrow from its official website:
    Download - Sparrow Wallet
  2. Copy the signed transaction file from the microSD card to your computer. Make sure you select Passport’s signed output, not the original unsigned file.
  3. Open Sparrow and connect it to a Bitcoin server. You can configure this under Settings → Server without creating or importing a wallet.
  4. Select File → Open Transaction → File, then choose your signed file.
  5. Review the destination address, amount and fee.
  6. If Sparrow confirms the transaction is fully signed, select Broadcast Transaction.
You should then be able to follow its status in Envoy. If Sparrow reports an error or says signatures are missing, send us the exact error message before creating another transaction.
Please do not enter your seed words into Sparrow or share them here. They are not needed for either method.
