Export Passport keystore with custom derivation path
Additionally, @kg2025 and @Satoshi_Nakamoto I am not able to verify what your config file may look like, but if you wanted the peace of mind that your setup indeed works, you can do two options.
  1. Reach out to help@unchained.com and just raise your general concerns with our support team, tell them Joe Brauckmann sent you over there and they can loop me in if needed.
  2. You can test signing with your current set up in Sparrow but only sign with the key in question and/or do NOT broadcast the transaction (especially for an IRA vault). Afterwards cancel the transaction. And soon you should also be able to test signing in Caravan as well.
I shot you an email!
Thanks @jbrauck! In this case I have done a few consolidation transactions so I know my Passport works as one of the signatures.
The thing I was wanting to do currently was perform the semi-annual device check. Without direct Passport support from the Unchained web interface I was trying to build the Coldcard file Unchained requests but I was unable to figure out how to configure the file for the device check to accept it.
I would obviously prefer direct Passport device support from Unchained, but I was hoping their was a simple work around I could use to do the device check.
