Envoy not showing received funds from another hot wallet
Running Envoy on android version: 2.3.0 (2030107)
I’m connected to my own private node running fulcrum. Sent funds from another hot wallet (muun) to envoy. Waited a few minutes and in envoy, the transaction is still not showing up in my activity menu in account details as pending waiting for confirmation. I also did a full sync by pulling down on the page to refresh and its still not showing transaction. Been over an hour and still nothing is showing up.
Verified on my own block explorer that it now has 6 confirmations. I then went to my receive page in envoy and its still showing the same receive address I originally used to send from muun to envoy. My understanding is that once a transaction has been received, envoy would automatically generate a new receive address. This has not happened and I think this tells me somehow envoy is not registering the received funds. Could it be a bug in envoy or possibly something with my personal node?
Try the steps below with a larger number first to see if it shows up. Could be some sort of gap limit issue. Let me know if it sorts if for you.
I keep getting the rescanning failed for mobile wallet message regardless of choosing 300, 500 or 1000 addresses. I’ve also noticed that under my privacy tab, for my personal node it says couldn’t reach node. Under block explorer I’m getting “could not reach block explorer”.
Whats wierd is on my laptop my sparrow wallet has no issue connecting to my personal node fulcrum using the same ssl address on port 50002. Also the same mempool onion address loads find when manually going to it through my tor browser on my laptop.
I do keep getting the issue establishing tor connectivity message in envoy at the top of the screen.
Almost certainly an issue with Tor on your phone inside Envoy then. Are you able to connect locally and turn on ‘Better Performance’ in the Envoy privacy screen just to see if it cures it?
Changed both node and block explorer to foundation (default) and then went to the mobile wallet account and rescanned it using 1000 addresses and it finally showed my transaction and funds. Does this mean envoy needs to be unistalled and reinstalled?
No need to reinstall. It just seems like there’s a Tor connectivity issue. You mentioned seeing repeated warnings in app.
Can you send some logs through to hello@foundation.xyz and I’ll take a look to see if there’s anything obvious in there. PLease also include phone make, model and OS version.
Just sent email with subject title same as this thread title.
I too am experiencing something similar. Made a deposit two days ago and i am still waiting on the funds to show up. Moved funds from Trezor to my passphrased account on to PPP. Two deposits went thru fine the third one showing up in activity but not as funds in my wallet. Went thru all of the above steps rescaned 100, 300 1000 rebooted device and Envoy still no funds but it clearly shows up in my activity as completed… Please advise!
Can you confirm if you’re using Tor and which node you’re connected to?
Iam not using TOR and i am using Foundations node… please advise
Is there anything U can recomend for me to do to retrieve my funds?
Are you sure you have the passphrase active on Passport Prime, and you’re re-scanning the correct account? The fact that you can see the specific transaction in the activity screen tells me that Envoy did catch the transaction.
What constitutes active on PPP? I see all of my BTC that I have transfered to the Passphrase account thats three deposits, the only exception is the one transaction that appears in the Activity from four days ago… but the funds are not in the acount. I even sent a small amount yesterday to see if it would push it thru still nothing. I can send U logs and screen shot if necessary. PLease advise…
Yes please do. Make sure you reference this thread when you email.
Just now sent the info to Ben… Logs and screenshots
Thank U for Ur attention to this matter… its quite unerving!
